Stuck filter trick
remrf
AZRF
4:27 AM
Tucson, Az.
I bought a group of 9 49 mm filters from ebay about two weeks ago. When they arrived they were screwed together with caps on both ends and two of them refused to unscrew (the one I wanted the most was one of them of course). They seemed to be locked tight together. I tried differing types of pressure on the filters but got nowhere. On a whim I stuck them in the freezer hoping perhaps the contraction in the cold would loosen them up. I put them in and about 15 seconds later I realized that I had set the wrong side down on the cold surface if I wanted the male threaded portion to contract. I pulled them back out to flip them over and realized that they were loose now. I unscrewed them with ease.
It took almost no time at all to work. I'm going to remember this trick.
My usual method when this happens is to use the sole of my sneaker. Put one filter against the sole, press and turn the other. Filters usually unscrew easily.
Peter
