Summicrom 40mm f2 VS. Voigtlander 40mm 1.2
Summilux 35/1.4 pre-asph:
40/1.4 Nokton:
Roland.
Thanks Pau. Should be visible now. BTW, the lux is older than the Summicron v4. One might argue that both Nokton and Summicron v4 designs are derived from the 35 Summilux.
I would love to see a reference about the Nokton lead contents, and it changing over time.
Roland.
Yes, we know that. I don´t know where you got the Summilux diagram but it doesn´t look correct to me.
Could it be a diagram from S/N 2166702 point change?
Possible. Check Puts' "Leica M-Lenses: Their Souls and Their Secrets". The basic element/group
configuration is identical to your reference (its first computation?) above.
In any case: do we have a Nokton/lead reference, please ?
Best,
Roland.
I´m interested in the Lead reference too. From what I understand, the tabbed 50mm Summicron and the current 50 with built-in lens hood, have the same lens cut - but different glass type and MC.
Regards,
RLouzan
Best,
Roland.
The 35mm Summilux-m pre-Asph is a 7 elements design. The difference in all this designs is in the rear cemented group.
Best,
RLouzan
Has to be: Summicron 35/2 pre-ASPH! The Summilux 35 pre-ASPH was a 8-element design, so is the new CV Nokton 35/1.4. The lens diagram looks quite equal - oni soit que mal y pense ...
Roland,
Maybe it´s not an error, they could have the same lens diagram after all:).
The 40mm Nokton is a fantastic lens.
Best,
RLouzan
