bobby_novatron
Photon Collector
The body is a difference of $3-4K BUT the S series cannot be used with M or T or R lenses. The cost of lenses is the majority cost of a system. I don't know that I'd call a brand new Leica Summicron-M 50mm f/2 APO "heritage or vintage glass", or even my lowly Summarit-M 75mm f/2.4 for that matter. My R lenses date from as far back as 1963, but they're generally right up to spec with 'modern' lenses ... a couple were still in production until 2006 or so.
The difference between a 33x44mm sensor and a 24x36 sensor is rather small in terms of what it will net you in DoF control, and there are a lot of extremely good, fast R and M lenses to take advantage of that would cost you tens of thousands of dollars to replicate in S lenses. Likewise, the difference between 24 and 39 Mpixel is pretty small. The adaptation can be done now, immediately, by stacking the already available M to T and R to M adapters, both from Leica and providing all the lens correction and EXIF data as desired.
I think we can all be pretty certain that Leica will use the new, updated sensor (or an even more recent derivative of it) in the next M "typ" series. Why wouldn't they?
Leica has achieved with the SL what most folks dream about: an optimized solution that allows use of (nearly) any lens they've ever made, all the way back to the 1930s. Can't say enough good about that. 🙂
G
+1 all good points, thanks G.
