filmtwit
Desperate but not serious
When will the insanity end?
http://www.techtoyreviews.com/ttartisans-launches-21mm-f1-5-lens-for-leica-m-mounts/
Now what we need are some new reasonably priced full frame Leica M bodies (film and digital).
How many times it is heavier and larger than M body? Looks like x2 at least.
Website says 405g. Not bad. AliExpress sells it too.
It's awesome DJ Optical and all these Artisans are coming out with these lenses. I had the 50/1.1 for a while and really liked the photos, but it was too big for using on rangefinders and I sold it.
I'm curious, what would be the situation that this lens shines over a slower and smaller 21mm lens like a CV 21/4? Night street scenes? I guess the same could be said about the 28/1.4, especially when a f2.8 max aperture lens is still fairly small. The larger size does not seem worth it, but I am probably missing the point 🙁.
The sweet spot for me for a regular use wide angle lens is 28mm.
Partly because my rf cameras still have frames in the vf for that.
I’m using the 7A 28 1.4 which is excellent.
I already have 25/21/18mm lenses but obviously use external finders for
those which is ok as I consider them more specialized.
Still I’ll look forward to some tests before I decide whether or not my life be complete without it...
21mm (and wider) are best for landscapes and close ups - very close up. Used close up with a narrow DOF you can get some very interesting photos. Unfortunately rangefinders don't allow focusing closeup. In this case something like 0.7m. At that focal length even an aperture of 1.5 gives a big DOF.
