james.liam
Seen the same color shift issues off an M240 as the M9. Don’t know if it’s less pronounced but doubt it. That’s why Cosina redesigned its UWA lenses.
You're well set up to find out, Raid, since you have both sensors. You just need to get your hands on the lens. I'd be curious to see what the actual results would be.How will the CV 50/2 APO-Lanthar perform on a CCD camera? If it is optimized for a CMOS sensor, will it be better or worse than on a CCD sensor?
I wonder if it simply the CMOS sensor or is it also the use of the SONY. What is the same lens had been used with an M10? Will the vignetting be also as bad?
My non-retro focus wide angle lenses cannot be mounted on my M cameras.
Thanks for the pics, I don't have that lens or I'd try the same on my M240.
Here is a 50mm f1.5 Nokton (M mount, first version) wide open on the M240 measuring exposure at the center and at the extreme corner.
Shawn
On RED, on the M240: Max 5280 Min 169: That is almost 5 F-Stops of vignetting. I have the same lens- the LTM Nokton 50/1.5 Aspheric. It just does not do this on my cameras.
The Leica M240 uses offset microlens arrays, and uses a custom architecture to move the light sensitive material closer to the surface of the sensor. This was done specifically to improve performance of light coming in off-nadir.
https://the.me/the-leica-m-max-sensor-explained/
Sensor architecture and the microlens array plays an important roll in performance. This is in addition to the IR filter stack. Off-nadir performance of the full-frame KAF-18500 is superior to the 1.3x crop KAF-10500 used in the M8. I believe sensor thinning techniques were used to improve performance.
Voigtlander has such nice offerings these days. Too bad I don't shoot a 50 much anymore.
Some of the beat recent offerings are elsewhere in the FL range; 2/35, 3,5/21, 1,4/21, 1,5/75. Take your pick. All of them are a better long-term choice than TT7 alternatives; they are indeed more expensive but should prove more durable and have a resale market if you choose to do so. A $150 lens has little residual value on resale when new samples are abundant. Only time will tell if the Chinese offerings will last over time.
Does anyone know anywhere in Europe taking pre-orders?
Adorama just started preorders on their site, should I buy from them or cameraquest if I want my lens earlier? Or should I just wait until the thing officially is in stock.
