Adding to the Hasselblad 1000f kit, among other things…
I just acquired two lenses for the Hasselblad - a 60mm f/5.6 Distagon and a 135mm f/3.5 Ektar. The Distagon is in fantastic shape, the Ektar is in okay shape. The rear element of the Ektar has some separation (rainbow) and focus is smooth but a bit stiff, but overall it's okay for my purposes. It just had a CLA so it’s about as good as it’s going to be.
I also managed to find an elusive item -- an original cable release adapter. These Hasselblads have a special threaded socket on the side of the camera for the cable release, and you either have to use a particular kind of (and very expensive) cable release or you have to use the adapter to take the universal cable release. Luckily I found the adapter, which are still relatively expensive items if you can track one down.
And finally - finally! - I ordered an Epson V850 scanner with the fluid mount. I've been wanting to get this scanner for a couple of years and finally decided to pull the trigger. My only concern is using the Silverfast software -- I know that Epson Scan and other software is much easier to use but from comparison tests that I've seen the results are clearly better using the Silverfast software. So I'm just going to have to knuckle-down and learn Silverfast, like it or not. Oh yeah and make some images that are worthy of scanning!
New Lenses by
Vince Lupo, on Flickr
