Hand Holdability...
Hand Holdability...
Camera mass is good. Mirror Lockup is good, and those are well known standards. To that, I add the self timer....and the old classic... the string pod.
The self timer relies on no time crunch on the shot. It does however, all you to concentrate on a steady hold when the shutter activates.
Set the timer, compose and half shutter expose the shot. Now press the last half of the shutter action. You then have 2 or ten seconds to concentrate on a steady hold. Works for me. Good for a stop or two.
The string pod is a good non-stretching cord. At on end is a round eye 1/4 inch bolt that screws into the tripod socket. At the other end is a loop that your foot fits in. Length is adjusted to your height... ground to eye. Then standing in the loop, hold the camera at the upper end of the string with slight tension. Shoot as normal, with the string pod steadying vertical movement of the camera. Works for me, good for a stop or two. Folds up into a pocketsize wad.
