Which wide angle lenses work very well with the M9?
I think the ray angle issue is certainly real, Raid. It's a question of what one is willing to accept as we look to the extreme edge of the image.
The CV 21 was just too compromised for me when I first got the M9 and saw it with the ZM18. I was going to sell the little CV, and I bought the SEM 21, which is great, and you could argue M9+SEM21 is hard to beat with any camera at base ISO (at 21mm). Certainly no DSLR zoom can do so, and I don't know a better 21 prime, unless you must have something faster.
However, the SEM is not small (not large), and valuable. The CV goes in any pocket. So I starting grabbing it and testing again this fall, as you can see in those first images. I did not have to use corner fix. Just that 21 elmairt profile.
I love those shots, period. Sure, you can see the lens get softer in the outer regions, and it's much more so than on film with that lens. I could have done five shots with my 28 and stitched them, I guess. But I like just the nice simple way, take one shot and see what you get. The CV imperfections are almost charming at times, like the edges of a 5cm sonnar like Brian loves. They are no better, that's for sure.
Try this with a 50:
L1053614 by unoh7, CV21/4
Yes, you can turn the M9 backwards and easily do a selfie in a car! Look at the mirror on the left edge. It's not fuzzy. LOL
Here it is wide open at F/4:
L1053613 by unoh7, on Flickr
I love the shot. I never once thought, oh! I wish i'd had the SEM21, those darn ray angles on the edge. In fact the shot has a look which is impossible at any other FL. To me the CV21/4+M9 is priceless: look what it gave my family. 🙂
What is so fun about 21 is you have incredible DOF, so you can zone focus and experiment:
L1054426-2 by unoh7, on Flickr
yes, from my bike in flight, the CV 21. If you check the original, you can see power lines over her RIGHT shoulder at a mile away leading right into the edge. None of the images i've posted here are cropped BTW. So perhaps you can see why I have no sympathy for the dismissal even of the CV21 on technical grounds for use with the M9. I don't deny it has problems. That's half the fun, like a sonnar 😉
Now, someday I will get a SEM18 to replace the ZM18. But the CV21 will stay, with it's more perfect and more costly friends, because it has what they do not: tininess. 🙂 Quirky charm just a bonus 😉
DSC00781 by unoh7, on Flickr
I set the M9 to pre-asph Elmarit 28mm with my Rokkor 28mm lems, and it also woprks well then. You seem to be quite happy with the CV 21/4. My copy of this lens is in S mount, so I cannot use it as it is on my M9, as you know.
Unoh7, I have been following this thread closely between you and Raid on the various lenses and Leica M9; and your composition + color put out, is some of the finest I have seen on here.
Another suggestion: the Leica 24 Elmarit M. It is one of my favorite lenses in terms of sharpness. If I remember correctly, it has only one aspherical lens surface and of course was designed for film. It is very sharp edge to edge even at full aperture and is only slightly "less wide" than the classic 21s. You might find it a bit too sharp if you are looking for some "character" in a lens for color images. I use mine almost exclusively for b&w. I love it also because I do not need a finder for it. I use the internal M9 viewfinder for framing (using the whole viewfinder for the 24) which of course is also used for focusing. This lens can be easily coded too. I have used the Zeiss 21mm on both a M9 and M8 and loved its images too. This thread does remind me that there are a lot of options for wide angles on the M9.
24 3.8 is a gem
My CV 25 is POS on digital and was one of the first made. Film was ok. Digi shows everything and my 25 has bad decentering, one side of image out of focus, the other better but not great. Stopping down helped little. I have a $200/300 paperweight.
12 and 15 are in the same box. I learn slowly.
Have looked at two 24 3.8 and both were sharp right into corners @ 3.8 on M9. Usual target is fine tree branches I put there on purpose.
Zeiss Biogon 21mm f2.8 is excellent on the M9. Code it as a 21mm Elmarit and the red edge is gone.
Zeiss Biogon 25mm f2.8 is also excellent. Code as 24mm Elmarit.
Voigtlander 15mm f4.5 is pretty good, and you can minimize red edge by coding it as the WATE at 16mm.
