hon910
Can I know if there is still a demand for Widelux F8 camera?
And what would be the reasonable market price for a good used condition?
I paid around $500 AUD for my F8 which is definitely at the lower end of the scale. It was an Ebay BIN that I spotted while browsing and couldn't resist.
There are some ridiculous prices being asked ... up to $1500 which is crazy!
$500 AUD is a great bargain.
Actually I have one Widelux F8 in good condition that I am planning to sell.
I just got it CLA by Precision Camera Works this year.
Everything works fine.
I only have the camera & an old soft case for it, no filters.
Planning to sell at US $900 (is it reasonable or too high or too low?).
I will probably post it in the classified later.
Anyone interested can PM me.
Where are the photos?
Well, I tested out my Widelux today - unfortunately it has banding.
So here are some pics - the last one displays the banding...
IMHO, this looks more like bromide drag than Widelux banding.
Also, I don't see the scratches in this image that are apparent in the others.
--Steve
What is the horizontal field-of-view (in degrees) captured by the Widelux?
The Widelux's 26mm swing lens gives a horizontal angle of coverage of 126 degrees (140 degrees diagonally). This is much more than the 71 degrees of the XPan's 45mm rectilinear lens.
Bromide drag - never thought of that. I developed this in a Phototherm, so it should have gotten adequate agitation, taht would be the indicator of bromide drag, right?
I sent a color off to be developed, so maybe I can check that for the same symptoms - then i could confirm banding, or better rule it out!
Thanks
I don't want to burst your bubble of hope but that is definitely banding. My F7 produces the same effect to lesser degree. It can be very hard to get rid of in the earlier cameras apparently. Exercising the shutter by rotating the turret at the offending speed (uncocked) may help ... just push it around with your finger and let it go as many times as you can be bothered.
An easy tell would be to see a scan of a complete home developed negative including perforations.
Bromide drag will only be seen on the spacing of the perforations and rarely the full width of the negative. Banding, by definition, must be present from edge to edge and of a uniform width.
