infrequent
Are you capturing a scene or the correct exposure? All of this seems rather opposite of actually going out there and taking shots which seem to be what Fuji X cameras excel at.
Yes! When using the camera in aperture-mode or p-mode the camera does good exposure, also with the histogram. It just does not sync with a light meter.
It is not a bit off; Sunny 16 is a bit off.Yeah when using sunny 16 it is a bit off. At first i thought that digital is more sensitive than film and that i need to be more spot on.
Why not use the XPro2 in one of the automatic modes and see how the exposure turns out before going to the expense of buying a light meter. I know you say you are in the habit of using a light meter, and old habits die hard, but how deep could the habit be if you don't even own a light meter.I guess i'll buy a meter and just start testing!
Found this!
https://photographylife.com/does-fuji-cheat-with-its-sensors/
Hi!
I have heard that the Fuji X series don't expose the same as other cameras. So if i would use a handheld meter it will not give the right exposure? I'm used to work with a handheld meter but sold it with my last Leica, i'm missing to shoot that way and want to try it with my x-pro2. But before i buy a new meter i was wondering if it will "work"?
Thanks!
Thats exactly the point, Fuji's are always around 1 stop off, so if the internal meter (as also other cameras) show ISO 100, the Fuji's shows ISO 200 for the same aperture settings. Probably a little marketing trick to get good DXO ratings.
No issue if you shoot with the internal meter in sense of correct exposure, but with external metering you should compensate.
Yogi
Man, this thread makes me very happy that I am happy with Fuji's metering and that I don't overthink this.
Taken together, how much variation do you think there is? One stop? Two stops? Enough to matter?This, like so many other questions and comments I see or hear about exposure, seems pointless if not actually ill formed. Although cameras are much more mechanically consistent than they were back in the days when they were all mechanical there's still sample variation in shuttet speeds, sensor response, lens magnification, aperture size and lens transmission ability (glass absorbs and reflects light so transmission is not necessarily consistent across lenses even if the aperture is identical) to make it difficult to answer this question definitely without a much more well thought out test program than I've ever seen anyone implement.
