Conceptually, a digital camera starts with a lens projecting an image on a CCD instead of film.
Instead of wet film processing, the sensor data is computer processed…whether the computer is on-board or external. The circuit board associated with the CCD is a [dedicated] computer.
Of course, the computer has to be powered and a device has to be attached to record the data. May the best battery, memory card or whatever is next wins. Samsung, Sandisk and many others will help.
A camera needs to be focused, and we have accepted manual. Ground glass is a way, rangefinder another, EVIL a third… The best is the type that let you see what the sensor sees…before, during and after the [exposure] fact. RF is the worst of the three, it does not even see what the taking lens sees. [However, we are talking about a dream RF here, so please don’t start…]
A shutter is a device that limits the period of exposure. The on/off switching of CCD achieves the same. Even Leica Geosystems (now renamed ERDAS) offers a shutter-less solid state aerial scanner that uses this technique…since 2001. Also the Rollei Electronic...no cocking needed and silent.
The more accurate timing device is not a mechanical watch movement but rather a quartz chip set. That debate was settled 40 years ago…even the Zurich Hauptbahnhof had sported a Citizen clock [in 1991]. 😱
Evenness in illumination is a universal problem but deemed worst in a dRF…hence the self-celebrated Leica 6-bit and offset micro lens…
However, there are plenty of credible reports that the 6-bit coding means more in alerting the on-board computer that a [less than perfect Leica-made] super-wide angle lens is mounted…so fix the collective but embarrassing and immediately observable chromatic aberrations first.
Lens mechanical and optical vignetting is common also to film cameras. A tried-and-true fix was anti-vignetting filter...on the lens
Pixel vignetting compounds the problem. The solution is to use a CCD with less hooding, such as the Sony HAD CCD-II…
In a dRF, this anti-pixel-vignetting filter can be simply coated also onto the micro lens substrate…just like that infamous M8 IR coating...so long as the CCD sensitivity can handle all that filtering with a usable range left over [same problem as was in film].
Some CCD now sports ISO 200~12,800 [such as the purportedly Sony-made chip used in the Nikon D3S]; wasting 2 stops still give you 200~3,200, matching Leica.
So Carl, talk to Sony…your business partner contract with them has another 4 years and 9 months remaining.
Considering product pricing:
Leica had set a bench mark of ~$7,000…2X the price of an M7, or 2X a bread-and-butter lens [I don’t care you had found a better deal on eBay].
The Zeiss Ikon ZM price settled at ~$1,500, and a bread-and-butter lens ~$1,000…but made in Japan.
Will that proven contractor Cosina accept a Manufacturing Order to build a ZMd targeting a MSRP of 2X ZM plus...after Zeiss had done the home work?
