Serenar 35mm f3.2 filter?
B-9
Devin Bro
11:30 AM
Michigan
Hello, i was curious if anyone has adapted this lens to mount filters, howd you manage it?
Thanks in advance for any responses!
According to Peter K's book "Canon Rangefinder Lenses", and depending on which version of the lens you have, it accepts either a 36mm push-on Series VI adapter or a 34mm screw-in Series VI adapter. The adapter unscrews in two halves to allow a filter to be inserted in the middle. The hood also screws into the adapter, and the Canon hood was a rectangular design used on both the 50/1.8 and the 35/3.2.
Canon's strategy was Series filters mounted in the lens hoods, in the case of this lens a Series VI filter.
If it has threads, they are 34mm. If not, you need a slip-on 36mm series adapter, from Canon, Kodak, Tiffen, or Ednalite. If you don't plan to use the Canon hood, Series V filters will do, but the matching Canon hood is Series VI sized.
My particular lens does not have threads. I have a few series iv filters, ill have to locate a adapter.
As for a hood, i managed to find a 37mm hood with a set pin mount. It should be here this week. Im hoping it will work without much hassle.
I waasnt able to find any canon hoods for sale.
