I have 4 raw developers I use. Most of the time it is the current version of Lightroom. Lightroom doesn't do direct monochrome conversions without demosaicing though.
For that I use Iridient Developer. The developer wrote all his own raw processors and sharpening methods and it gives great results. Brian was way ahead of the curve with Fuji xtrans files for example and it also handles Merrill files and has an extended dynamic range monochrome mode in them too. To go straight to B&W with demosaicing you just select that as the raw process.
As an example a raw file at default ...
Then going straight to monochrome without demosaicing...
and showing the detail at 300% zoom.
I used Iridient with the comparison between the K3 color and monochrome raw files.
I use DXO occasionally as it has great film looks, its NR is fantastic, Viewpoint corrections for geometry, and volume anamorphosis.
The last one I use every once in awhile is RPP64 as it has a unique look to it with regards to color. It has an Ektar emulation which is beautiful. Also has looks for prints on different types of paper.
