Seraj
Student of Photography
So let me see if I have this right:
Un-metered
M3 - The timeless classic, solid build, great if I intend to stick with just 50mm lenses or longer. Can technically be used with wider lenses using "goggle" attachments. Oldest of the bunch though so be wary of de-silvered viewfinders, etc. Cloth shutter DO NOT AIM AT SUN. Earlier models (DS) don't have as many features but some seem to prefer the build? I was told to search for 950k + by a person of Leica technical expertise... So a tad confused on that count.
M2 - Later model contrary to naming convention. More frame lines specifically to deal with wide angle lenses, but also a timeless classic much like the M3. Slight changes to winding mechanisms, etc.
M4/M4-2/M4-p: These are the ones I am a little confused about. "cheaper", more frame lines, easier to load... but advantage other than price?
Thus Begins Metering:
M5 - "The Beautiful *******" if you will. Hated initially for its bulk and weight in comparison to earlier models, came into its own in recent years because of these very things. Has a slightly out set shutter dial which you can see the readout in the viewfinder. (ugly shutter dial IMO, but function over form?). Also contains all the innovations of the M2/4 etc. Quietest shutter?
M6/varients - "thus begins modernity", a vast difference in magnifications, the "original" being a .72, but there is also a .58 and .85 (TTL). Resembles the more modern Leica M- cameras. Have metering. MORE magnification = easier ability to compose on standard lenses? Less = ability to use 35mm and wider?
M7 - Electronic + Mechanical, Auto-Exposure capable. No real idea about this one or if it fits into my budget with a lens.
MP - "Mechanical Perfection", Leica AG's attempt at rekindling the Leitz M3 magic with a throwback camera. Out of my budget even used I am guessing. But drops many of the more modern features for a "classic feel"
Thank you for putting up with all this, I really want to make sure the first one I get fits within my project needs. This project will be used to build a portfolio of film work on top of my digital to send to my top choice schools. I can't thank you enough for helping me with this.
If I have this right, It's almost lens break down time.
Un-metered
