ESG said:
It sort-of does.
But it misses this point: that two objects can have totally different spectral responses, even though they appear under a certain light to be the same colour. That being the case, a camera will record them to be the same colour, and no amount of post-processing will separate them. However, change the light - or, equivalently, change the filter - and because of the difference pigments or dyes in the objects they will no longer appear to match. And suddenly the camera will record them differently too.
For exactly the same reason, it's possible to have two fabrics that match well in daylight, but put them under a fluorescent tube and they differ markedly in colour.
Finding a value for the red, the green and the blue in an image doesn't tell you anything about how that same scene appears under different filters.
I don't understand. What has matamerism got to do with this problem? The spectral response of the film can also cause a match or mismatch simply because it is not the same as the eye.
Color contrast filters used in black and white photography don't isolate single wavelengths. The idea is to suppress fairly large areas of the spectrum of the image. If I use a filter that covers the same spectral response as one of the color channels, I can immitate it electronically. No big deal. For the most part, I can make changes to image contrast electronically or with filters. Whether they are "excalty" the same does not matter - you probably cannot tell looking at an image. If I get the result I want, why does the process matter?
Now some filters cannot be reproduced, infrared, hydrogen alpha, etc. But those are very specialized filters. As far as metemerism is concerned, that has nothing to do with this as you would first have to prove the film has the exact same response as the eye and CCDs don't, not to mention that filters would make a noticable difference as they are most likely not narrowband and would encompass the spectral response of the object. But even then, matamerism is not an issue with monochromatic images. (BTW, film and the eye do not have the same spectral response.)
Naturally, the electronic way could be argued "better" as the entire color information is preserved and the image can be adjusted at home using all color channels. This is something you are not going to be able to do with B&W film. The choice is up to the photographer.
Now, if this is just a film vs. digital argument, it is weak. Actually, it can't be supported. However you want to control tonal contrast, either method is fine and one is not "superior" to the other. All this comes down to is personal preference.
- From a film photographer who uses filters and prints in a real darkroom.
