ruby.monkey
Wear the strap across your chest messenger-style and you should have no fatigue problems with any of the ones you already own.
Oscuro
He's French, I'm Italian.
Again, +1 I use one with a D3/50mm and an X100. Could probably fit a 28-300 in there too....carry gear to produce work but also edit work and transmit work (on occasion) for long periods. easy access, surprising capacity and they can then be tossed in the backpack and carried on with you.
with that approach, I can spend months on the road with everything I need. add a GOOD cable mesh lock (backpack size) and hit the open road!
Ditched the ipad for a iphone 6+ and I can work for theoretically unlimited periods, with no base, no fixed address, no direction home, and nobody's fingers in my eyes.
Rangefinder 35
I had pretty good experience carrying Lowepro Inverse (I think it's 200AW model), while backpacking in S. America. I had 1- Leica M, 1- Zeiss Ikon body with 21 and 35 mm lenses attached, and 1- 85/4 in the divider. It was out of the way of my backpack, and carried on my hips in front, so I hadn't felt it much.
