Vince Lupo
Whatever
Thanks for the info -- I do think that it is a Kiev 4a. If you look at the rewind knob, it is not the same as a Contax rewind knob. Plus the serial number puts in the range of the no-name Contax serial numbers.
There's two types of Contax logo. Somewhere in the 'F' prefix serial number range the script changed slightly and the cross-bar on the 't' moved lower.Unfortunately even the name plate is from a Kiev "no name". The Contax is engraved not stamped in like a real Contax and the "t" is wrong. A real Contax "t" is crossed lower. The serial number shows it as a 1963 Kiev serial number as the "no name Contaxes" also use. Someone later thought they could increase the value by forging the Contax name on this one.
Not sure whether to have put this in the Zeiss Contax section or the Russian FSU section, so we'll try it here....
Anyone have any knowledge of these 'no name' Contax cameras? I understand they were made in the early 1960's, but does anyone have any idea of how many were made? Are they especially rare and valuable? I'm looking at one now, and it's in relatively decent shape (comes with the lens), but not sure if they're worth pursuing or not.
If anyone has any kernels of wisdom they'd be willing to share, I'd be greatly appreciative!
there are at least two versions of this camera.
the Jena version made right after the war in Russia with Zeiss parts and tooling -- worth bucks
and the much more common no name Kiev from the early 1980's. Those were sold off for $99 while supplies lasted.
..."the Jena version made right after the war in Russia with Zeiss parts and tooling -- worth bucks"...
The "Jena" Contax, was built in Saalfeld (Soviet Occupied Germany, or "SBZ"), with the new production lines made up by the Zeiss technicians, after the loss of the original machines, damaged during their shipping to the USSR. These latter lines, were then sent to Ukraine, along with "volunteer" German personnel.
The first "russian" Contax is the 1947-made Kiev -including german parts- that is also quite rare (BTW, it's my avatar...).
All the best,
E.L.
I think it's a pretty neat camera -- I have a roll of XP2 in it now, and hopefully will put it through its paces tomorrow.
As far as the coated element goes, the rear element appears to be coated as well. Did pre-War coated Sonnars have their rear elements coated?
So how does one tell the difference between one of the 'no name' cameras and one of the 'regular production' Kievs?
Not so, Zeiss coated some of the batches of Contax lenses as early as 1936/37.
