We are now categorizing individuals based on their sartorial choices? "DSLR-men"? I am giving you a road map -- the one true correct logical path to navigate a sea of confusing choices.
If these choices were programmed into Watson or some other narrow AI Von Neumann box with sophisticated algorithms designed for THE one optimal price/performance solution for gear choice, there is no doubt in my mind its and my own choices would exacty align.
1. APS digital cameras? No. Since when was APS ever any good? Smaller? Even worse. This negates 85% of all gear out there excluding cell phones.
2. Small format film? No. Shoot it for fun. But it's obsolete. (Medium and large format film is stil fine, however.)
3. That leaves you with only full frame cameras. Which ones are best?
4. Answer: the ones with the best sensor specs. And there is great and surprising variance within this realm such as the surprisingly lackluster performance of Canon and Leica sensors according to DXO. That leaves with two vendor choices: Nikon or Sony (and one Pentax) based on impartial published independent evaluation available to all.
5. Sony is eliminated for a host of reasons pertaining to the bodies Sony chose to put their great sensors in. That leaves only Nikon (and a Pentax -- which is a viable contrarian choice...)
6. Which Nikon? The one with the highest price/performance ratio.
... and that clearly is a used Nikon D600 which has been greatly devalued due to some early production problems and associated bad PR by way of blog chatter...
I have applied equally impeccabe rationale to what lenses, what order to purchase them in -- and why. I won't rehash this now.
Nikon D600 with low actuations and the 50/1.4 AF-D. Used. ~ $870. (Add other lenses later...)
This clearly resolves the upper limit of the price/perforance ratio of currently available gear. Hands down. Bar none.
Let's see what Mr. Rockwell has to say about the matter -- for ducks. Well, well, well --
"The Nikon D600 is Nikon's best digital camera ever, at any price. The D600 has better image quality than any of Nikon's professional cameras like the $6,000 D4, and the D600 is the smallest and lightest full-frame digital camera ever from Nikon. The D600 has the best ergonomics and handling of any Nikon DSLR."
-- and he published this
before one could be had used for $6-700 bucks. It slightly outperforms the current production D750 (94-93 per DXO) with the same resolution spec of 24MP, more than enough and relevant for some time to come, and bumps up against the top-of-the-line D810 rated at 97.
https://kenrockwell.com/nikon/d600.htm
