Noctilux standard lens on M7..ND filter for daylight
35mmdelux
Veni, vidi, vici
5:53 AM
Los Angeles, CA
Hello All,
My Noctilux is going to be my standard lens on my M7. I'd like to shoot between f/2.0 and f/4.0 with 160/asa Fuji in the daylight. What ND filter would allow me to shoot these settings?
Thank you -- Paul
My math might be wrong (it was in my original post ... I am watching boxing at the moment and my mind is numb). So hopefully somebody will double check the math.
I used sunny 16. Please adjust accordingly if you use "sunny 11."
Looks like you need a four stop filter since the M7 has shutter speeds to 1/1000 right?
f/16 f/11 f/8 f/5.6 f/4 f/2.8 f/2
no filter 160 320 640 1280 2560 5120 10240
1 stop 80 160 320 640 1280 2560 5120
2 stop 40 80 160 320 640 1280 2560
3 stop 20 40 80 160 320 640 1280
4 stop 10 20 40 80 160 320 640
5 stop 5 10 20 40 80 160 320
Since it's OK to overexpose negative film by at least a stop, you could easily get by with a 2 stop filter. A three stop filter would be OK, though.
That, of course, is predicated on your shooting in bright, sunny conditions.
I have a ND8 filter (3x factor ?), used it once and never again ! The vignetting was horrible ... Better use some Velvia 50, KR-64 or PanF at 25ISO, IMHO.
yehh, I have tried various ND filters on my noctiluxes, and have eXpeienced a loss of image resolution... @ f/1 or f/1.2 DOF thats a big deal... in which case...My Jupiters Look better wide open🙂
OP wants to shoot at ISO 160.
Assuming broad daylight and the sunny 16 rule applies: 160 @ f/16; 320 @ f/11; 640 @ f/8; 1280 @ f/5.6; 2560 @ f/4.0; 5120 @ f/2.8; 10240 @ f/2.0.
The fastest speed on his M7 is, nominally, 1/1000. You must halve 10240 four times to get a shutter speed under the 1/1000 limit on the Leica M7.
Therefore, OP needs a 16x (2 to the power of 4) neutral density filter to shoot at such apertures under direct sun at f/2 to f/4 using ISO 160 film.
As David Elliott illustrates also.
