JeremyLangford
I'd really Leica Leica
I guess you're after this look, hey?
Sorry about the grain. The original is 6x7.
I love the look of that sky.
TriX in HC-110 is my preferred film/developer combination. I can shoot very smooth images with great tones at 250 or push the same film to a lovely gritty 3200 - all depending on the processing. A very flexible combination once you learn the different ways to use it.
I like a yellow filter for contrast in the sky, but I'll throw on a red if I really want it dramatic.
So if I were to push the 400 Tri-X, I'd have to shoot at 1600, which seems too high. I will be doing a lot of shooting outside into the sky (I will probably have a new red filter that I will want to try out) and inside my school.
Don't forget a red 25a filter will cost you 3 stops of light. So, shooting Tri-X with the filter on the lens, you gain two stops by shooting at 1600 and lose three for a net loss of one stop or an equivalent ISO of 200.
Before you go off the deep end, you should develop some B&W at normal speed and normally exposed, using normal films. From experience, when I was your age I was all over the map, and I really never got where I wanted to be until I was almost 30. Shoot rolls at normal speed (box speed) develop nomally, enjoy what you have, learn your camera, its meter, learn your film, and developer. Then try some filters. I still get fooled by filters (check out 'film factor filters' on Google. And I do everything manually. When you use a red filter it darkens blue (right?) which includes shadows so you get more contrast. Do you want high contrast or practically black and white.
In my stumbling manner, I was trying to say; when you are learning, don't hopelessly increase the number of variables. Get an established base of knowledge and then expand from there. There will be plenty of time for a red filter.
Agreed. Though it is fun to play around!
Go here for more information about filter factorshttp://en.wikipedia.org/wiki/Filter_factor
I guess I'm lucky to have TTL metering so that I don't have to compensate for what my light meter tells me.
Except that meters are easily fooled. Best to know what's going on and what to expect.
I whole-heartedly agree with charjohncarter - get a solid base of experience with one film and one developer following a basic processing schema. Then introduce variables. No use seeing what a red filter does with your combination if you don't know what to reasonably expect without it.
My comments were just to indicate that there is nothing wrong with the HC-110 and TriX combination, and over the years, I've worked out a pretty good system. But by over the years, I mean over the past 20 years of shooting and processing pretty constantly.
Jeremy,
You have gotten a whole classroom year of great information here free for nothing.
How do I add contrast to a print using an enlarger. I know that my teacher has a little book of enlarger colored filters. Do these add contrast to an already B&W negative?
