Fantastic image Jackson! Please give some background story to that one!
Also - how are you scanning your negs with the DSLR?
Welcome!
ty!
for the image, took a stroll through the Shanghai Zoo to test out the newly bought m6 and walked through the giraffe enclosure and saw this wonderful creative in the indoor enclosure. Almost wished I had a roll of colored film in the camera when I took the picture as everything was black and white except the giraffe and the background accent wall which was aqua. The black and white turned out well with the contrast though.
for DSLR scanning I've been experimenting with it for a while on my 500cm images. Black and white is pretty easy as you invert the image and it'll yield good results. Color was a bit challenging to get consistent results due to the different orange color cast of each film stock. I initially setup a manual profile for each film stock in capture one, and as I scanned each image it would automatically invert and profile each image to a perfect picture, took me a long time to get each profile right though...
for a simpler fool proof method, I later found this tutorial:
http://www.mfphotography.ca/michael...-guide-to-scanning-film-with-a-digital-camera
it's a bit of a read but yields very good consistent results for colored film. If you're scanning with a 24mp dslr + 100mm macro lens, I've printed this giraffe image to a 50x30cm print from a 35mm film scan with great results. If you use 50mp 5DSR or medium format digi back to scan your film, you can print pretty big from a 35mm neg!
i use a 5dmk2 + 100mm macro with 24mm extension tube to scan 35mm film negs. have yet to try the 5dsr to scan them, but would literally double the print size i'd imagine. Much better clarity and resolution than from the best drum scanners from a lab, and with bracketing on the DSLR if need, dynamic range won't be an issue. Takes a bit of work and cloning out dust is a bit of a pain, but saves you thousands of dollars on a top notch scanner.
edit: from the tutorial, before you apply the actions, make sure you crop out the borders of the color negs before running the action. Not so much of an issue for the 35mm films for me, but for my 120 hasselblad images, I like keeping the borders, and the pure black + white borders makes for some weird color shifts when you run the actions.
