PKR
WRT the shutter, I just want to know what the sync speed is, and whether I can use 2nd curtain flash.
Electronically controlled vertical-travel focal-plane ? Any Specs.?
It is unlikely to be a leaf-shutter. They are usually located within the optical train at the nodal point.
I have not seen mentioned anywhere whether the shutter is horizontal or vertical traveling, nor sync. speed.
I'm guessing (I can't remember if it's okay to guess here) they would use a proven unit; not an original design. Maybe a Copal variant. The Fuji engineers seem to lunch a lot with the Nikon bunch. I'll bet the shutter was discussed over some high-temp green tea. So, what has Nikon used in their APS-C cameras?
......So, what has Nikon used in their APS-C cameras?
5 fps, live view, 1/4000 shutter speed... I sure hope that this shutter is built like a tank. A camera can look great and have wonderful features, but it must work and continue to work.
Space will be at a premium in the X100 body, with the intrusive lens, sensor with IR/AA filter, rear LCD, plus the complex viewfinder. It's smaller than the HRF and G1/G2, more like a CLE in size... which of course did have a horizontal-run focal plane shutter. So is there room for the Copal?
What about a rotary shutter, à la Pen F, updated to run faster? That one had flash sync at all speeds, too...
I know to each their own, but I think flash sync speed is overrated unless you want to take unnatural looking fill-flash in harsh light. Sure, if it CAN sync at a high speed then why not, but it certainly would be among the last of the things I would worry about when buying a camera like this. I wouldn't think this would be a camera that would scream for use of flash...not like a medium format camera or a wedding-style DSLR. But, as I said, to each their own.
Yes, but has there ever been a serious camera in the last 30 years that did not have an accessory flash? Just because it comes with one doesn't mean it will be good or necessary...
But again, I hope it is good for the sake of people who like flash! It's just something I never find very useful in my own work, apart from occasionally with a studio lighting setup. But if you are a strobist, I hope it works well for you. I just meant to point out that I don't think flash will be a large consideration for most people interested in the camera...especially since it is f/2 and goes to ISO 12,800.
I am straightly "available light".
The built-in flash should be good enough to trigger slaves flash units.
