cmedin
Sorry, Nick, you're 100% wrong. I always decide on aperture and fiddle with shutter speed afterwards on my all-manual cameras; on the automagic ones I leave them permanently in aperture priority mode.NickTrop said:Nope. I am 100% correct. Unconventional wisdom is often regarded as "weird" until others put aside their biases, have a moment of intellectual honesty, and "see the light". The only place to put a shutter speed setting that is not inconvenient to the extent that you will use your manual camera as a "virtual shutter priority" camera, and accept whatever aperture your camera gives you, is if it's on the lens barrel. You use your manual camera as a shutter priority camera almost every time. You either accept the aperture and "acquiesce" aesthetic control over the most important aspect of the image - the DOF, to the camera; or you're futzing with your shutter settings (unlikely) to get the aperture you want, but by that time, your subject just got on the bus and is 1/2-way to Schenectady already.
No other camera - Leicas, Contaxes, Hexars, Zeissesses, Voigtlander-branded Cosinas... regardless of cost gives you the amount of speed required for "decisive moment capture" in combination with the level of aesthetic control, as a photograhic tool, than the RF+aperture priority design of the Electro series.
PS: it helps to pre-set the aperture and shutter speed for the environment if you want 'action' shots.
PPS: It's certainly faster and easier to change shutter speeds on my Leica gear than flipping the lens towards me so I can see what the aperture's at and adjust it. 🙂
