back alley
IMAGES
Joe, I think you are right. I just ordered a CV28 on RFF for my RD1.
i saw that...the 28 and the 50!
good lenses.
Ezzie, how is it with the 90?
Nobody else uses a 90mm on the rd1?
Is it worthlessly small in the finder?
How abt focusing a 90 at f2 and close focus, would it be a problem?
did they arrive yet?
That's super easy to adjust on the original R-D1. I see you have the R-D1s - is that the one where they made it more difficult or was it the R-D1x (I don't know if this change was more than a rumour anyway)?(the image in my finder patch is just above the original image so I can't never nail it).
Do you mean the patch doesn't move vertically at all (infinity focus), when you adjust the third screw, or you just can't get it to match? If you can get it to move, you should be able to make it match. The adjustment you need to do is however very small so you can easily overdo it. If the patch does not move vertically, then you may have a problem.Unfortunately, I wasn't successful with that. I already tried adjusting those three screws but the patch image keeps without matching the original subject.
i love the 15 on the rd1...but it takes more work to get a good shot. i have to be constantly aware of where i am...which is usually too far from my subject...i prefer the 21 for that reason.
Hi, Joe,
Do you use VF for your 21? and which one?
I just added a 21mm lens into my R-D1 lens line. and found using a 35mm VF (sold my 28mm VF :bang🙂 is adequate for most cases, although I don't like to using a VF.
Regards,
hi robin!
i don't use an external vf for any of my lenses...i just check the lcd and guesstimate from then on.
When I had the rd1/s
I Loved the 50mm ....the old 1.5 50 summarit
-and 50 pre asph lux were my Favs
Did not own one then but would have Loved to try the 28 elmarit asph or the 21 angulon
on the rd1
on the rd1
the 28 is my least fave lens on the rd1.
