Camera-Scan Challenge for Color-Neg, as Automatic as Possible
Time to summarize:
Time to summarize:
Key things I've concluded about camera-scans of color Negatives
1. Getting enough resolution is easy, color and tonality are more difficult
2. Illuminate the negative with a high CRI source (incandescent, LED, or flash)
3. Shoot RAW with a good macro lens
4. Simple inversion gives the weakest results. Better w/ purpose-built software or a non-linear inversion.
[ Edit Fall, 2018 with a new option ]
- Camera scan capture of the negative, shoot RAW, import into Lightroom
- Run Negative Lab Pro, a new Lightroom plug-in
See this thread here on RFF about NLP. I now recommend this option: very good color, almost fully automatic, and it's in Lightroom.
[ Edit March 19, 2018 with a new option ]
A new and very effective process:
- Camera scan capture of the negative, shoot raw, open in Photoshop, holding histogram away from the edges.
- Sample film rebate or a VERY dark shadow area to get film base
- Run Adrian Gabor's CN-Scan-Inversion action, available here. See result in #127 this thread.
[ Remainder of text below from Nov 2017 ]
Minimalist approach:
- Camera scan capture of the negative, shoot raw, open in Photoshop or Lightroom
- Levels adjustment to give a good histogram (centered, wide, but not to the edges)
- Invert the image
- Bend the inversion curve, or add one more curves adjustment, bringing down all the mid-tones
- Add an "auto" adjustment
Better Color:
- Levels adjustment to give a good histogram (centered, not to the edges)
- Invert the image with Jack Jzagaja's curve, or apply ColorPerfect (ColorNEG option)
Very Good Color Method #1 (via Photoshop)
- Use MakeTiff or dcraw to create linear tiff with no adjustments (will look very dark)
- Open in Photoshop and apply ColorPerfect (ColorNeg, film type, clipping, gray point, perhaps +sat)
- Add a Photoshop "auto" adjustment
Very Good Color Method #2 (via VueScan)
- Launch VueScan. Input from file. Select options (film type, check clipping, gray point)
- Select destination & file type, then hit "Scan" to process the image
- Adjust in program of your choice
- (Silverfast reportedly can do the same thing.)
Notes:
- MakeTiff is free, whether or not you buy ColorPerfect
- DCraw is free, but it's a command-line program, no easy user interface
- They do the same thing, results are a little different
- The DCRaw command: dcraw -v -w -H 0 -o 0 -q 3 -4 -T fileName
- ColorNeg settings: FilmType, ShadowClip 1.0, HighlightClip 0.25 250, rest to taste
Comments?
For the "simplest" approach, bending the curve something like this seems to work OK:
I do know with photoshop and color perfect you can “batch” process several files at once with “setting from last scan”. So basically you edit one photo with the correct film profile, and then batch the rest - the only thing you must physically do is save the photos.
I go between the Luminous Landscape preset (more involved than just autos TBH) and using MakeTiff and color perfect. So I’m fairly familiar with both. Sometimes the Lu-La looks pretty good, but generally the ColorPerfect version looks better. So, ColorPerfect in PS with “batch” process is pretty one click as it gets really.
Hmm... Not too happy with straight inversion:
I have NOT been happy with straight inversions. The white and black points are OK, but all the tones in between are too hot. That's exactly what one should expect, it's the non-linear response of film. For math types: the film characteristic curve has a straight line portion in log-log space.
@brbo, try the same straight inversion, but do it with curves, and bend your curve like I showed in #63 above. It will look a lot better.
I understand: Convert your RAW with this DCraw command, then invert in Photoshop using the above curve.
dcraw.exe -v -w -H 0 -o 0 -q 3 -4 -T fileName.arw
I understand: Run your RAW file through MakeTiff, then invert in Photoshop using the above curve.
